09-11-2019 03:59 PM
09-12-2019 01:17 AM
Hello,
A 430 EX can be set up off camera and fired remotely, however you will need the pop up flash on your EOS 80D to control this. The 430 EX flash does not use the RT or radio trigger system to fire the flash, instead the flash on the EOS 80D will be the controller to let your 430 EX know when to fire.
For a detailed guide on this you can refrence the manual of the 430 EX Speedlite on page 23 which will show menu options and diagrams on how you should se the camera and flash up.
09-11-2019 09:58 PM
09-12-2019 12:29 AM
@sxs9825 wrote:
I got the 430 ex to flash, but I could not figure out how to get it flash without the pop up one also going off.
You may be seeing a pre-flash that may be what makes the 430 EX fire at all. Generally speaking, a Canon flash without "RT" in its name needs an optical signal in order to fire remotely. And if what you're seeing is a pre-flash, it won't affect the picture (unless, possibly, if makes the subject blink).
You seem to be asking questions that ought to be answered, to at least some degree of detail, by the user manual (either that of the flash, that of the camera, or both). Are you sure you've given the manuals the attention that they deserve?
09-12-2019 01:17 AM
Hello,
09-12-2019 10:41 AM
09-12-2019 02:33 PM
Which manual, there are usually 2, an abbreviated one and a full one.
09-12-2019 11:02 AM
09-12-2019 02:50 PM
09-12-2019 09:44 PM
The other one is PDF only, you can get it on the Canon support site.
09-12-2019 09:47 PM
Try here:
http://gdlp01.c-wss.com/gds/4/0300022454/03/eos80d-im3-en.pdf
Note that the one in the box says "basic instruction manual"
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
