04-11-2013 11:13 PM
I have a 7Dand also a 600EX-RT. I am wanting to know that if I buy another 600EX Flash will it work with the radio transmitter on the 7D instead of buying a ST-E3-RT and then another flash later? I am looking for advice and/or suggestions. Thanks
04-11-2013 11:28 PM - edited 04-11-2013 11:36 PM
Yes. One 600 will be set up as the master and the other as the slave.
There are some minor limitations when using the 7D wih a 600 such as some of the settings cannot be set via the camera but instead must be set directly on the Speedlite. There are some other limitation throughout the manual. I think if you search for "released" in the PDF manual you will find all those differences.
Edit: A word about the ST-E3-RT. Despite that it doesn't have a AF assist beam, I have become a fan of the ST-E3-RT because of it very small size, weight, and ease of use. Once you have your Speedlites, you might want to consider one these.
04-11-2013 11:33 PM
04-15-2013 01:58 AM
Some time ago I had similar questions about what doesn't work with the 600EX-RT and the EOS 7D I wrote a blog post with my results
http://www.p4pictures.com/2012/07/using-the-speedlite-600ex-rt-with-pre-2012-eos-cameras/
Brian / p4pictures
