600EX-RT on 7D
photomad
I have a 7Dand also a 600EX-RT. I am wanting to know that if I buy another 600EX Flash will it work with the radio transmitter on the 7D instead of buying a ST-E3-RT and then another flash later? I am looking for advice and/or suggestions. Thanks
3 REPLIES 3
7D5D
Rising Star
Yes.  One 600 will be set up as the master and the other as the slave.
There are some minor limitations when using the 7D wih a 600 such as some of the settings cannot be set via the camera but instead must be set directly on the Speedlite.  There are some other limitation throughout the manual.  I think if you search for "released" in the PDF manual you will find all those differences.
Edit:  A word about the ST-E3-RT.   Despite that it doesn't have a AF assist beam, I have become a fan of the ST-E3-RT because of it very small size, weight, and ease of use.  Once you have your Speedlites, you might want to consider one these.
Awesome. Thanks for the quick response. I am easy about using the flash for set up if it cant be done on camera because that will change when they go on a 5D MkIII.
Some time ago I had similar questions about what doesn't  work with the 600EX-RT and the EOS 7D I wrote a blog post with my results
http://www.p4pictures.com/2012/07/using-the-speedlite-600ex-rt-with-pre-2012-eos-cameras/
Brian / p4pictures
Brian
