06-25-2020 03:16 AM
I spent a couple hours tonight on DPP for Mac editing pictures and "saving" using the "save" button in the top center of the screen and manually driving to a folder I created for finished images. I finished my work for the night and closed DPP. When I went to that folder to verify my work was saved... no images. Anybody know if that data is saved somewhere or am I just out my time. This is extremely frustrating.
07-13-2020 05:53 PM
The terminology is a bit confusing at first if you're not used to working with DPP4.
What you have done by selecting "Save" is to have saved a file (think of it as a recipe) of all the adjustments you've made for each individual image. Re-open an image in DPP4 and it should show you the image with your previous edits applied.
Then select the same image and click on "Convert & Save". You can then save a seperate copy of the image, with the edits applied, as either a JPEG or a TIFF file. And your original RAW file will remain unchanged, as will the "recipe" of your edits attached to it.
