11-22-2018 09:20 PM
Ever since I bought my 5D Mk4 around 6 months ago and got the DPP 4 software I haven't been able to install it and it fails with the message 'Failed to Install' on both that and the lens registration utility. In my process of troubleshooting I actually removed all of my Canon software and then found I couldn't re-install the Map Utility program either which was working before but now gave the same error. Strangely though the EOS Utility and Photo Stitch were fine going back on, they must not integrate into the computers system as deeply.
After many attempts with additional profiles and other attempts at installation, I gave up. Canon support weren't much help so I shelved it until today where I tried again. I again contacted support and they suggested all of the things I'd tried many times before. However, they suggested a new user profile which I'd also done before but this time I had the idea to enable and log on instead with the built in administrator account (which I'd disabled and left there in case of log in issues with my account). When I ran the installers in that account they installed immediately indicating a profile issue. However, when I logged off and back onto my account, disabled the adminstrator account again, both DPP 4 and Map Utility now worked.
So, I think that the Windows 10 permission issue that seems to plague admin user accounts even though they are in the administrators group is the issue here. It seems that my own user admin account couldn't access areas that the built in administrator account could. Once the installer could access the areas and install its components then it was fine for all user accounts to use.
Hope this helps someone.
10-12-2020 06:16 AM
So, for anyone who is still having this issue and I am as of October 2020, the workaround is to place the DPP installer somewhere on the public desktop and then switch accounts to the built-in admin. Find the installer file on the desktop and run it.
The DPP software and lens tool will now install, this also works with DPP updates. If you get any messages about installing for all users click on yes.
Switch back to your own account by logging the built-in Admin off and logging back into your own account. DPP will now work correctly.
Hope this helps and let's hope Canon sorts this profile issue out soon?
VB
11-24-2018 09:29 AM
Not sure what "Windows 10 permissions issue seems to plague admin user accounts even though they are in the administrators group is the issue here" you are referring to.
The name of a user account does not affect the permissions it is assigned. While your behavior does sound like a permissions or profile issue, its not related to the name of the user account built-in or otherwise.
10-11-2020 05:51 AM
The built-in Admin fixed it for me as well, thanks
10-12-2020 06:16 AM
VB
