09-30-2024 04:48 PM - last edited on 10-01-2024 03:57 PM by Mike
Canon printer MFB 32 CDW image class will not scan to computer. It worked fine last week. Now it says connect to computer when you try to scan.
09-30-2024 05:00 PM
Do you mean MF632?
How is it connected to the computer? USB? Wired network? WiFi (wireless)?
10-01-2024 06:05 PM
Yes, I thought the 6 was a lowercase B
MF 632 C dw
MF632CD
it is connected wirelessly
10-02-2024 11:01 PM
Have you rebooted the printer to see if anything changes?
The first thing I advise is to give the printer a static IP address. This means it will not change. Letting DHCP on your router assign its address can be problematic, because it's not guaranteed to stay the same. The router then has to be told what the static address is, so it will be reserved for the printer. The router supplier or manufacturer can help you with this.
After you've done this, see if the WiFi connection is more reliable.
