12-30-2024 01:49 AM
Ever since I updated to Windows 11, version 24H2, I get the following error message. It used to work fine before the Windows update, and it still works find on my Mac. So, it cannot be a cable or connection problem. Please help.
12-30-2024 06:08 AM
Copied from another post about this:
Complete directions (from Jdecker1) all in one place to fix this issue caused by the recent Windows update.
1) Exit out of the CaptureOnTouch out of your system tray
2) Go to this folder
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CaptureOnTouch\Tool
3) Click on the shortcut for System Configuration
4) Under Thin Client Mode, change from Disabled to Citrix: Twain Redirection, then click ok.
5) Open up CaptureOntouch and the problem is fixed.
12-30-2024 06:08 AM
12-30-2024 06:22 AM
Thanks, but I cannot find such a folder:
12-30-2024 08:16 AM
Thanks! I got it to work.
12-30-2024 08:31 AM
I had the same issue, so I right clicked on the application and opened the folder it was in. Glad to hear you got it working!
01-23-2025 03:06 PM
Unfortunately, this solution did not work for me. Followed the directions to the T. Running Windows 11 x64 with 24H2.
