02-05-2025 03:25 AM
I am using a GX7021 to scan.
It has worked well for me for 18 months … until the last couple of days (i am guessing a recent firmware update may be at fault, though i thought it was working well for at least a few days after the firmware update … )
It used to be that a "Custom" scan for a multi-page scan to PDF would take a few seconds a page, and scanning several pages would be done quickly (using the IJ Scan Lite utility on my mac).
Now, the most recent issue is:
1. press "Custom" in IJ Scan Lite
2. see "Searching for scanners…" then simultaneously, will see the usual scanning in progress dialogs on both the mac and operation panel
3. after a while, the scanner just goes back to the home screen on the operation panel, and IJ Scan Lite just silently fails.
this is maddening, because the scanner has worked well and quickly for a long time, and i've done thousands of scans with it.
i've investigated the wifi.
i've tried hooking it up with Wifi direct rather than a router.
i've tried looking for another firmware update, but the scanner says it's up to date.
i've tried using the "Driver" button in IJ Scan Utility Lite, and it will preview the scan for me, but the "Scanning…" dialog at the bottom that looks like it is supposed to be a dialog box really doesn't advance.
glad to try any and all suggestions to get this back to normal.
02-05-2025 03:50 AM
additional info: i have downloaded mfuu-mac-gx7000-1_2-ea7.dmg printer update from the canon website; it shows it is attempting to install firmware 1.160 . my printer/scanner already has firmware 3.010 .
it seems a little odd to me that my firmware is so much more "advanced" than the download from the website, which is dated 2024.11.18, and says it is firmware update 1.2 …
02-05-2025 03:52 AM
additional info: i am having the same problem when connected with USB cable. i am only guessing, of course, but the issue seems to be with the scanning software on the printer/scanner itself, and not with the connection.
02-28-2025 08:48 PM
I am also suddenly having issues with my Canon MX7021 scanner after working perfectly fine even yesterday. It keeps failing mid-scan -- it will say "documents left on ADF" even though it appeared to simply stop scanning halfway through the 2nd page of a 2-pg. document. Also, often trying to initiate a scan from the IJ Scan Utility will result in an error message saying "cannot communicate with printer," although when I start the scan from the touchscreen on the printer, my computer reacts, so clearly they CAN communicate with each other, but the scan just fails partway through. Have you found any solution?
02-28-2025 08:53 PM
Well, I moved my router and it works now. Good luck to you!
