CapturePerfect settings - replacing imageFORMULA DR-4010C with DR-6010C
dougj1963
We currently have a DR4010C and are replacing it with a DR6010C.  We use CapturePerfect to scan.  What can we do so that we don't have to redo all of our current CapturePerfect settings?  I know the current CapturePerfect setting are in C:\Users\username\AppData\Roaming\Canon Electronics\Cappe3.  There is one ini file and lots of .dat files.  I have a general idea as to how all of these files are used.  Again, what the easiest way to replace scanner hardware and not have to recreate CapturePerfect settings.  Thanks!
2 REPLIES 2
Moderator
Moderator
Thanks for joining the conversation, dougj1963!
So that the Community can help you better, we need to know exactly which operating system is running on your computer (i.e. Windows or macOS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
dougj1963
BTW we are using Windows 10 and CapturePerfect 3.1.
Holiday
