DR-G1100 Where to download CapturePerfect 3.1? Or better?
jhood
Have had the same ImageFormula DR-G1100 running for quite some time attached to an old Windows 10 PC.   Realized it was finally time to upgrade the PC, but can't find the Capture Perfect 3.1 disk anywhere.   Can't find it available to download anywhere either.
Is it available anywhere?   Is there equivalent software?
We have an imprinter with the scanner and it is important that we be able to modify the counter on the imprinter which is why looking for CapturePerfect 3.1.   That worked perfectly.   If there is something else that does it, open to ideas.
Thanks
3 REPLIES 3
Greetings ,
All of the downloads available for your product are available on its support portal.
https://www.usa.canon.com/support/p/imageformula-dr-g1100-document-scanner
I see CaptureOnTouch v4 available.
Hope this helps.  🙂
I downloaded that, but it didn't seem to have all of the options for the imprinter.   We need the ability to just change the counter from time to time depending on what project we're working on.  Maybe I missed that in there, I'll have to look again.
Capture Perfect 3.1.55 is also available, but you must have the original media to install v3.1 in order to upgrade to 3.1.55.  I realize this is your dilemma.
You can try contacting support.  Its possible they can provide for you.
Holiday
