07-17-2023 06:22 AM
I have a Canon 9950f scanner that has been working great for many years. I have used it off and on, sometimes going for years without using it. However, today when I tried to scan an image, it filled the image with rainbow-colored lines. The lines do not look like banding, but rather thin colored lines for various colors. I am using a Windows 10 machine. I am wondering if my sensor is bad. Do you have any suggestions?
Thank you for your time and assistance.
07-18-2023 10:19 AM
Thanks for letting us know what Canon product you've got. The CanoScan 9950F is an older model which we have retired. While that means that Canon USA no longer offers direct support for it, your friends here in the Canon Community are welcome to offer suggestions!
You can also speak with a Canon Upgrade Program specialist to help you score a modern replacement that would meet your current needs at a discount. You can reach them weekdays and Saturdays at 1-866-443-8002.
Hope this helps!
07-25-2023 10:47 AM
Hi Danny,
I have been using a Canon 9950F scanner for years and am very satisfied with its performance. However, the scanner is no longer being manufactured, and I need a replacement.
I have researched the available options and have found that there is no direct replacement for the 9950F. The closest equivalent is the Epson Perfection V600, a high-quality scanner with similar features.
I am reluctant to purchase an Epson scanner as I have been a loyal Canon customer for many years. However, I am open to considering other brands if there is a scanner that meets my needs.
I would appreciate your assistance in finding a suitable replacement scanner. My primary requirements are:
Thanks!
02-01-2024 03:01 PM
For what it's worth, I have the same issue with my 9950F when scanning 35 mm slides (I only use the scanner for transparency scanning). However, it only happens when I scan at 4800 dpi. 2400 dpi works fine in both JPEG and TIF with 48 bit RGB. I was also have issues with it freezing up on occasion but replacing the DC power adapter seems to have resolved that issue. I'm using VueScan on both a Windows 10 and 11 machine (same results regardless).
