08-02-2022
11:08 PM
08:32 AM
Hello! I'm having an issue with connecting my xha1 camcorder to my computer. I'm using a USB to IEEE 4 pin Firewire adapter to connect to the camcorder.
Every time I connect the camera to my computer, it is not recognized. Even if I connect to another USB port, it still won't recognize the camera.
Do I need to use a proper adapter or give up?
08-03-2022 09:15 AM
Are you using something similar to this?
If so, it won't work. The PIN out on the cable is not correct. You will need something like this:
08-03-2022 08:30 AM
Hi, JesseR5!
So that the Community can help you better, we need to know exactly which operating system is running on your computer (i.e. Windows or macOS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
08-03-2022 09:01 AM
Which adapter? AFAIK, there is no easy way to get from USB to firewire. Macs use thunderbolt->firewire.
08-03-2022 09:15 AM
08-04-2022 12:16 AM
I will look into that. Thank you!
08-04-2022 12:17 AM
My computer's OS is Windows 11.
08-04-2022 11:17 AM - edited 08-04-2022 11:37 PM
Something like the above is under $20. Windows includes a basic video editor (look in the Photos App) if you don't have something more robust.
08-04-2022 11:25 AM
Great advice, Rick!
08-10-2022 09:37 PM
Do I need that chipset for that firewire?
