04-04-2023 01:20 PM
I want to connect my new Canon XF605 as a webcam
When I go to Settings (item 7) the "USB (Type-C) Mode" setting is greyed out and I cannot change it.
Does anyone know how to enable this so I can make the change needed?
Thanks
12-24-2023 12:01 PM
I'm sure this is one of those "terrible interface" issues with a very simple but ming-bogglingly obscure and technical contingency answer (i.e. "Of COURSE if you have the widget A/B sync flibbertyfloo dynamics level set to MEDIUM you can't use USB Mode!!!!")
The answer will surely be to go to some seemingly-unrelated menu area to an indecipherable choice on a never-used feature and change from one setting you don't understand to another setting that has no discernable meaning and THAT will allow you to use USB (Type C) Mode
12-24-2023 03:55 PM
@jfremer wrote:I'm sure this is one of those "terrible interface" issues with a very simple but ming-bogglingly obscure and technical contingency answer (i.e. "Of COURSE if you have the widget A/B sync flibbertyfloo dynamics level set to MEDIUM you can't use USB Mode!!!!")
Happy Holidays,
This post is 8 months old. The Camera has 2 USB ports. There is a clear explanation. 🤔
The USB host terminal is available for future functionality expansion.
The USB-C port
The notes indicate the function cannot be used simultaneously with the Browser Remote function (A 184), XC Protocol (A 191), still image recording or during IP streaming.
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
12-24-2023 04:06 PM - edited 12-24-2023 04:06 PM
I'm trying to determine how your comment explains why the choice to configure the USB (Type-C) Mode is greyed out and what else needs to be changed (or what needs to be done) to get access to it. The manual clearly shows that the USB-C port is the one used for the web functionality. In my case I connected my computer to the camera via USB-C and had the Canon webcam app running. All references say I need to set the USB (Type-C) Mode menu choices, but the choice on the camera is (as I posted previously) GREYED OUT.
I've worked on dozens of cameras from different manufacturers and this is clearly a CLASSIC case of UNDER DOCUMENTATION. I'm pretty sure I have to change some other setting on the camera to enable this menu setting, but there is absolutely no documentation of dependencies. Regardless--if you sell a camera and proclaim in all of your marketing that you can use it as a webcam you should supply instructions on how this is done and what variables might interfere with the ability to use the feature.
BUT... there is absolutely no documentation.
04-25-2024 06:48 AM
The USB cable needs to be unplugged to change this setting. As soon as you attach the cable it becomes greyed out.
