03-11-2021 10:31 AM
I just picked up my XA40 on Monday, I updated to the latest Firmware 1.0.1.0 mainly for the Custom Picture profiles. I have seen these for several other models and that are have some defaule settings for CP1 - CP6, but when I look at these profiles, there are all set to Normal?
Where is Wide DR, Canon Log 3, EPS Std.?
Do these have to be loaded seperatly?
Where do I get them to load them?
03-11-2021 11:19 AM - edited 03-11-2021 11:20 AM
FYI, in looking at the user manual, I see no trace of the word 'Wide' or 'Log' regarding gamma. I also went to the Canon web page for the XA40, expanded all of the sections under Features, but also found nothing stating the camera has Wide DR or any Canon log.
03-11-2021 11:29 AM
So I am asking because I am seeing these profiels for XA50/55 that have updated their Firmware.
I do see that Canon states "Adds [EOS Standard] and [Production Camera] color matrix presets to custom picture modes." for the XA50 - and I assumed that tif they took the time to do create them for the XA50, and took the time to add the ability to the XA40, they would also preload the profiles.
But I guess that was is a big assumption...
03-11-2021 03:40 PM
I bought an XA40 a few weeks ago and the first thing I did was install the latest firmware hoping to see the custom profiles. Unfortunately like you have found they did'nt show on the XA40. However with the updated firmware I started getting recording error messages so finished up getting the camera replaced. As yet I havn't updated the replacement camcorders firmware for fear of getting the error messages back. I'm unsure just what I'm missing by not updating to be honest.
03-11-2021 06:18 PM
Only the XF400/405, XA50/55 and HF-G60 get the full CP feature set:
https://www.youtube.com/watch?v=Xg92WLdqM5A
The XA40/45 and HF-G50 get a limited CP feature set - namely the option to switch between Normal and Standard BT709 gamma, Normal being the default in preset CP1 and the option to edit other image characterstics and save them as user-defined custom presets.
07-26-2021 09:04 PM
Canon, I call bull**bleep**! I have search CP1-6 and I see all the settings, but I don't have a Master's in Cinematography to understand all the crap you plugged in there. This camera is not targeted at professional filmmakers! You gave the 50 color profiles - yet not the 40. This is a LAZY Bull**bleep** move, and as a Nikon guy, now I remember why I am a Nikon guy!
FYI: Anyone interested in a slightly used XA40?
09-23-2022 03:05 AM
This question is fairly old. I came here with the same question, but I figured it out. So in case someone else has the same question...
I have a XA50, I assume the setup is the same for XA40.
Press Menu button (on back of camera).
Under the Camera tab, 5th screen, look for 'CP Function' option. By default it is off. Turn it on.
Exit the Menu, and go to the on-screen FUNC button. Scroll down and you should see the CP Setting options. It replaces the "Looks" option.
