R5c auto ISO goes extremely dark
bill_richardson
Hello all. I am using an R5c for photos. Unfortunately I made the mistake of letting a fellow photographer use my camera to test a new lens. He changed all my settings and it has taken a long time to get them all figured out and fixed.  However one problem that I cannot figure out is the Auto ISO.
I do sports photography and sometimes use auto iso depending on the situation. It never gave me a problem till now.  When on auto iso the pic stays dark. Like now I am in my living room in the evening and is extremely dark.  I take auto off and I go up to around 12k iso 2.8 and 1/200. The pic looks good then. As soon as I go to auto iso... dark again.
I don't know what could be causing this.  Any ideas that I can explore?
Thanks,
Bill
4 REPLIES 4
Anonymous
Not applicable
Probably the easiest way to sort this out would be to reset the camera settings and custom functions back to default values.
This is from the R5 manual, but may apply to your camera. It concerns setting ISO limits in the menus.
Yep... already did a reset due to the other things that the guy changed. I was in the menus earlier and looked at that. It is exactly those min and max settings. I guess they are stock or standard settings.
Thanks
Hi Bill,
Please listen to Bob's recommendation. Reset your main and custom settings and be on your way.  Don't waste your time trying to figure out what this other person did or didn't do, what they changed , etc.  Review your manual, then sit down with the camera and go through it's menus.  It starts to make sense, believe me.  Are the first few times a little challenging sure, but it starts to become second nature the more you use it.
The R5 C also allows to you to back up its settings to an SD card.  The photo side of the R5 C really isn't that bad.  The 13 programmable buttons in cinema OS are way more fun.  🤣
If you don't have an ac adapter or USB-C PD get one.  Now you can spend an unlimited amount of time in the camera's menus.  Bottom line, don't be intimidated.  It's a well thought out menu structure with a flow.  Spend some time in it and it won't seem so intimidating.. Once you have things the way you like, make a backup of your settings.  You may never use it, but it's peace of mind.  Experimentation is the best way to get the most out of your camera.
Anonymous
Not applicable
Did you reset custom functions also?
In some cameras you can also set limits on the shutter speed and f-stop limits.
