Example footage of 410 Mbps Intra-frame (C70/C300 III) anywhere? [SOLVED]
rs-eos
Coming up empty so far when doing searches for sample footage I can play with from the C70 or even C300 III.
Specifically, I want to test footage that was captured with the 410 Mbps Intra-frame codec (10 bit 4:2:2).  Preferably 23.98P, but 29.97P would be good too.
I have an 18 core iMac Pro with external RAID drives, and use Final Cut Pro.  Before I purchase new equipment and move to a different workflow, I'd like to see how working with such footage will pan out.
Thank you.
Edit: I have since obtain some sample footage; works a-ok on my setup.
Ricky
0 REPLIES 0
