EXPOSING C80 TOOLS
Thefilmaddict
I'm new to Canon but I am trying to master the C80.  I like to use False color and zebra to help with exposure.  What value should I set my high zebra setting to prevent clipping?  Would you set it to 100 and then when you see 100 zebras in your shots highlights, just close your iris down (or adjust ISO or ND) to make the Zebra pattern disappear?  As far as false color, should I try to avoid anything hitting red that I care about?
My gut tells me this is the right way, but I want to make sure it's correct.  NOTE:  this is reading the levels with a display LUT on, not the flat LOG image.
0 REPLIES 0
