EOS R5 C won't focus on talking head
waller540
I was hoping someone might be able to help with an autofocus problem on the r5c. I'm sure it used to be fine, and is only happening more recently. But I can shoot several minutes of talking head video and it not focus. In this I'm using a canon rf 15 35mm f2.8 lens. But it happens with others. Settings attached. Many thanks
PXL_20251117_173344687.jpgPXL_20251117_173351162.jpgA010C720_25090983_CANON.01_32_52_20.Still001.jpg
9 REPLIES 9
I have this body and the same lens.
What firmware version are you running?
Your video looks to be underexposed.
What shooting mode are you in?
Thanks for your reply. Should being underexposed by a small amount effect the autofocus that much? Especially with me moving around a bit over the course of 5 minutes and it not focusing at all?
Firmware: 1.0.5.1
Recording mode: normal recording, 25fps
I am updating the firmware now - should that matter for autofocus?
thanks
Autofocus enhancements were made available in 1.0.4.1 and again in 1.0.1.1 (latest ss of this posting).
You already have these if you're running. 1.0.5.1.  Not at home at the moment. I'll look at your settings when I get home shortly.
Try changing your AF Frame to small.
Are you tapping or using the joystick to select your subject?
Any progress here?
Thanks, I'll try. I use neither as I'm filming myself talk. So I set up, hit record, sit and go.
Based on your description, it doesn't look like the camera is tracking properly.  I'm sure there's nothing wrong with it. It's just going to be a matter of you getting it dialed in.
I'll provide detailed settings later today.
Here's what's missing
Since you are filming yourself, the camera has to be set so that it will track subjects as they exit and re-enter the frame (You).
IamintheUK
Rising Star
Rising Star
I'm not surprised it won't focus on you .Like the location you are in you are severely under-exposed so the autofocus is focusing on the brightly lit trees in the background. This is the sort of thing that happens in low light with contrast based autofocus.
__________________________________________________________________________________________
EOS C100 mk2 with a Canon EF-S 18-135mm IS STM, and a Sigma EF mount 10mm-20mm EX DC HSM wide angle - Zoom H2Essential - Dell 8700 i7-4790 3.6Ghz, 24GB Ram, Win 10, Nvidia GTX 1060 6GB - DaVinci Resolve Studio 20.3 - Blackmagic Speed Editor - Presonus Faderport 1.
My bad, I've been busy with house projects and haven't gotten around to providing him with suggested settings.
Agree with you about the underexposure I mentioned that in my first reply 😉
