04-26-2023 03:59 PM
Hi there
I recently started shooing my C70 in Raw LT and I noticed that digital IS is greyed out when shooting in this rec format.
When I switch into XF-AVC 10bit I can turn digital IS on and off again.
Seems strange.
Does anyone know about this?
I assume that if I see digital IS turned on in the other format it remains on when I switch to Raw LT.
Thanks Laurence
04-27-2023 03:33 AM
This isn't exactly a secret; it's in the manual, page 82, "Image Stabilization".
I don't know the reason, but I would guess it's because you're recording from the entire sensor in RAW, so there's no slack to move the image around to stabilise it. (Digital IS -- as opposed to lens-based IS -- means simply moving the image around to counteract camera shake. So you're capturing a larger area of the sensor than appears in your final film. If your film contains the entire sensor already, then there's no way to move the image around.)
Well, the manual states that there's no digital IS in RAW, so I would guess no.
04-27-2023 03:33 AM
04-27-2023 11:14 AM
thanks a mill. L
