03-26-2024 06:52 PM
I noticed while recording video outside that there is a light flicker that occurs. Even using tripod with a subject in focus, I can see slight variations with lighting. I have looked at various options to see what the issue could be without success. Any suggestions.
https://www.youtube.com/watch?v=gbjlIv729eI
03-29-2024 01:15 AM
Hi there,
Based on what you describe there are a few options which might help. Maybe the best option to maintain total control over exposure at all times would be to shoot in the Manual Exposure Mode (M)2, that way the camera is not consistently trying to adjust to the lighting conditions but stays with the settings you set it for. The other option would be to change the metering mode in your exposure menu to [Spot Metering], this would let you tell the camera a specific site to meter the exposure from, and as long as that area stays consistent the exposure should not change much.
03-28-2024 06:03 PM
Hi astrebel,
I'm sorry to hear you are seeing flickering while shooting in sunlight. Unfortunately we are not able to access YouTube on our Canon work computers, so I'm unable to see your example video. Is the flickering happening in all light conditions, or is is only happening when you shoot in sunlight? Were there any artificial lights nearby that may have been casting light into your shot? What frame rate and resolution were you recording in?
03-28-2024 06:11 PM
Hi Hazel_T,
It only seems to be an issue outside in the sunlight. It is only really noticeable when the sunlight is casting on outside walls. It seems the camera is auto balance for the light and subjects within frame. At the time we were shooting at 1920x1080 at 59.64P.
03-29-2024 01:15 AM
Hi there,
04-01-2024 11:48 AM
The manual adjustment will have to be our work around. It just mean we will have to plan our shots better. Having a steady exposure will also make any post-edits easier too.
