01-12-2017 09:07 AM
I am not recording the classes just using the cam cabled to TV for fly tying demonstrations. I don't want the icons to show.
01-12-2017 05:06 PM
Hi Hansy,
Thank you for posting.
If you select [Output Onscreen Displays] from menu and set it to [off], data displayed on the camcorders LCD screen will not appear on the TV screen. To access this screen, touch the "Home" icon, then choose "Other Settings" (The screwdriver & Hammer icon".
On the next screen, select the display (middle) tab, then choose "Onscreen display". On the next screen, choose "Off" to remove most of the icons. Now, touch the back arrow and "X" out of the menu.
01-12-2017 05:06 PM
Hi Hansy,
01-12-2017 06:27 PM
Wow! Thanks to Richard Canon product expert. Quick response and it works exactly as I wanted. When I did this procedure I could still see the icons on the camcorder screen but when it is connected to the tv you do not see them.
Thank you,
Hansy
