10-10-2022 02:34 PM - edited 10-10-2022 02:40 PM
Hey everyone!
I've been having some difficulty getting crisp, sharp wide shots with my Canon C70 and was wondering if anyone else is having this issue. I am nailing focus as best as I can, but when I get home and start working with the footage, it looks like mud instead of beautiful 4k footage I am expecting; it's almost as if the camera is not in focus.
Has anyone else experienced this issue? I sometimes have trouble with focus in general with the C70, but find that in super wide shots, it really fails and the footage is beyond disappointing. Attached is a link to an example shot from this past weekend, shot using a 16mm RF, f7, IS 800, ND6, 4k. {{ Was a super bright day, with harsh light and shadow }} My go-to method is one-touch focus using the screen. I'll lock the small focus box onto a subject until it looks good / gets the green bounding box.
Any help would be amazing! I thought the bitrate was the issue but I don't think that is it. At my wits end! thousands of dollars spend on new gear and ... this is the best wide shot I can get in 4k?!
Example shot here:
https://www.dropbox.com/s/zw6oixjpukwtr4d/ceremony.00_07_05_01.Still020.jpg?dl=0
10-10-2022 02:49 PM
Were you in auto-focus or manual focus? Did you use any of the focus assist features? To my eye, it appears that the focus was not on the bride, but a bit closer to the camera.
Also, what was the shutter set to? If set to shutter angle, what frame per second were you capturing? I think the exposure is good overal, but bride seems a tad underexposed. Sunny 16 says ISO 100 at 1/100 s and f/16. ISO 800 would give +3 stops, approx 1/60s would give another + 1 stop and approx f/8 would give another + 2. So to offset that, ND of 6 stops would do it. Did you try false color for this particular scene?
10-10-2022 02:53 PM - edited 10-10-2022 02:55 PM
Hi Ricky!
Thanks for reply!
I use 'one touch' focus most of the time, which is an auto focus but only when I hold the button down on a selected area. Once I lock focus, I leave it alone. And I agree!!! I don't know why the focus is better in the foreground!
My angle is locked at 180 degrees / 23.98fps. I did not try false color { have never used it } and I typically keep my C70 at its native 800 unless it starts getting dark, then I push up from there. I may have shot this at 640 ISO come to think of it as even with ND6 it was still too bright.
03-09-2023 01:14 PM
Hi there, I just read your post RE canon c70 blurry content on wide.
im suffering the same situation.
Did you manage to sort?
I am highly disappointed considering the £ cost, wide angle just looks frankly soft,
I did expect a less sharp result as the camera tends not to add too much sharpness, overall it’s sadly lacking!!
any help, greatly appreciated. J
