C70 Internal ND error at ND2
Danielagre
Hi,I recently bought a used C70, everything seems to be working fine UNTIL I switch to ND2.  The internal ND’s make a weird sound and then the ND2 turns into ND—— and the text turns red.  From this point the ND won’t change until I turn the camera off and on.  As soon as I turn the camera back on, I need to quickly change the ND to 0 or ND4.  If I hesitate on ND2, within a few seconds it will turn red and freeze again.
Has anyone encountered this problem?  Apparently the camera just came back from Canon before I bought it so I’m alarmed by this ND error.
(Canon C70 with latest 1.6 firmware)
Thanks!
1 REPLY 1
rs-eos
Was this a refurbished item you purchased from Canon? Or are you saying you bought it from someone? If the latter, did they have a CarePak (the unused portion could be transferred to you)
You’ll either need to sent it in for repair or look at returning the item and getting a refund.
Ricky
Holiday
