03-21-2015 12:19 AM
Is it possible to change the aperture on the C100 mkii without the grip unit attached? It seems the aperture will change if I push auto iris, but I can't exactly pick an exact aperture this way. Seems silly to have such a major function disabled when you strip the camera down.
03-24-2015 07:21 AM
Hi AdamRosenberg!
Thanks for posting.
The aperture is something usually adjusted through the main dial on the grip unit. If you will not have the grip unit attached, you can use a remote, like the RC-V100 or you can connect the camcorder to a network and use the browser remote feature by connecting to the camcorder with a tablet or computer.
04-22-2015 02:12 PM
03-24-2015 07:21 AM
Hi AdamRosenberg!
Thanks for posting.
03-27-2015 03:27 PM
Mike - this can't be the only solution to the problem. For those of using the camera on a gimbal system, dismounting the camera and reattaching the grip to simply adjust the aperture is a massive headache.
My understanding was the new joystick on the viewer would allow you to operate without the side grip. What is another menu-based solution that we can utilize?
Alex Schwindt
04-22-2015 02:12 PM
04-22-2015 02:14 PM
Ah ha! I knew there had to be a way. Thanks Bramsey!
