12-12-2020 03:31 AM
Hay there people.✌🏽
Just upgraded my laptop to the new 2020 macbook pro running the M1 chipset and using Big Sur OS and my problem is when i goto print i get the error message that there is an unrecovereable USB error 😩
As ive just spent 2 grand on the laptop Im not ready to have to buy a new printer.
Canon dont seem to support this printer anymore and im wondering if anyone has had this problem but has managed to fix this issue? My computer "sees" the printer but when i send a job to it it just gives me this error message.
Thanks in advance ATB
Alex.
12-12-2020 07:38 AM
What if you try to connect printer via WiFi
12-13-2020 03:39 AM
12-13-2020 08:29 AM
@alexbehrendt
Unfortunately, when you make these types of decisions, you must also be willing to accept what comes with them.
M1 - LIke most Apple stuff I'm sure its really cool, but it ends there. I'm sure patiece will win the day, but, you are going to have wait some additional time for manufacturers to write drivers for the M1's ARM based architechture in addition to everything else.
Its unlikely your 9500 will ever work with the M1. You might be able to solve the USB issue with a different adapter. However, there are no drivers available for the 9500 since 10.9 Mavericks
So unless you are going to use one or more of the less reliable "Print Server" type of methods you pointed out.. Connect to router, connect to always on PC / Older MAC, you may likely be facing a situation where you will need to throw more money at this to solve. Or at the very least spend time none of us has to manage what we all know is a cumbersome unreliable way to share a printer.
