pixma pro 100
jonrud
HI I live in the UK and am purchasing a Pixma Pro 100 from the US will I have problems with UK ink cartridges. Thanks
6 REPLIES 6
jrhoffman75
From website it looks like UK printers also use CL-42 inks. You should be fine.
Many thank I have also found out that the Pixma Pro 100 is one of the printers that is not regionalised, The only thing I have to worry about now is the power but i understand it will run on 100v/240v so that should be fine as we are on 230v.
The back of the printer has the European label on it so I see no reason that it won't work.
EOS 1DX and many lenses.
Had printer delivered to day and alls well very happy. We really get ripped off here in the UK, the printer here is around £400 I shipped it from Florida brand new in box inc postage for £140. What I cant get my head around is that from Florida to Heathrow took 3 days we live 70 miles from Heathrow but that took 7 days maybe we should take a leaf out of your transport book. Many thanks for all your replies now all I have to do is learn how to use the beast.
Now that you have this guy .........
First, you must not let the printer set anything.  Turn off every bit off control it has.  You can do this with the Canon My Printer under the Printer Settings tab (software that comes with the printer).  Do you know how?  I will guess, yes, for now but if you don't get back to me.
Second, you need to have your photo editor (like Photoshop, Lightroom, etc) handle all the settings and color matching.  You know how to do this? I prefer Photoshop and I use AdobeRGB color space. <--- set that!
And lastly, it is essential you get some settings on your monitor that somewhat matches what the printer is printing.  Your printer may be doing exactly what you are telling it to do and you have no idea it is, because your monitor is so far off.  If you don't do this step, you can forget the other steps.  However, there are only a few things that you need to be concerned with. You don't need any fancy extra add-ins to do this.  No additional software or gadgets, etc.
Most people set their monitors too bright.
You must get the gray-scale very close.  You need to get the brightness very close and you need the contrast very close.
After you do these things you can make adjustments to your prints by just looking at your screen.  Because you know the monitor and printer are on the same level.  One more point, you can NOT get a printer to print every color exactly the way you saw it.  It isn't possible as all colors and adjustments effect all others.  My goal is to get the skin tones right.  That is what people notice most. Remember you are dealing with two different disciplines here.  One is colored light and the other is colored dyes.  They are not the same thing.
For instance, I know my Pro-100 tends to print darker than what I see on the monitor (typical).  So, I automatically know to set it's prints 1/2 to one stop brighter in Photoshop, in my case.  It also prints with a slightly warn tone.  Most of the time, with portraits especially, this if OK but sometimes it is not.  In that case I adjust the "temp" setting slightly cooler in PS.
All the Canon photo printers I have ever seen have this warm/magenta cast.  Canon engineers must prefer this look.  It can not be changed.  You need to "fix" it in post.
Make sure you have the correct ICC profiles and you are using Canon brand ink and paper until you get good with the printer.  Very, very important, otherwise you don't know if the printer is doing exactly what you are telling it to or not.
Important is, use the USB connection until everything is right.  You are just adding another issue when you try to set up the printing and the wireless all at the same time.  Just like using Canon branded products until it is a go.  Use a real printer USB cable.  Not just any old USB cable. Get everything right before you explore.
HI at the moment I am half way through a house move so I am unable to use the printer yet, but will be intouch when the move is complete and my office is finished many thanks for your reply and look forward to contacting you shortly.
