imagePROGRAF PRO-1000 - I can't find "avoid print abrasion" + Color output is way output is way off
benprintshop
Hello!  Any help would be greatly appreciated!
Cheers,
By the end of April, I had completed the proofing process and was ready for production on a 5 x 7 greeting card. The final proofed master file was printed with these settings:
  • 7 x 10 60lb Pecos River Gloss card stock from Red River Paper
  • PSD file / 300 DPI / RGB 16bit
  • Canon Pro 1000 with RR Pecos River Gloss V-1 printer profile for Canon.
  • MacBook Pro 14 / Sequoia 15.4.1
  • Unsure which version of PS prior to 26.6.1 I was using, but most likely the prior version.
I installed two updates early last week:
  • Ps 26.6.1
  • the V-2 printing profiles from Red River for canon.
Three errors are now occurring and I have not been able to clear them:
  1. I cannot seem to find many print settings in the Ps printing dialogued, including the critical setting of “avoid abrasion” setting.
  2. An error on the printer itself occurs:
    1. “Size or type of the paper loaded in the top feed is different from the print settings” screen two: “check whether the paper that matches the following settings is loaded: Page size “Other” “type: pro platinum”
  3. Most critically: The print output is completely out of whack from the proofed master copy I had.
Troubleshooting I’ve done so far:
  • Reverted Photoshop all the way back to v25, still can’t find the avoid abrasion settings.
  • Uninstalled RR profiles
  • Uninstalled Canon Pro 1000
  • Restarted the laptop
  • Re-installed the printer
  • Re-installed V-1 of the Pecos River Gloss profile
  • Created a brand-new greeting card file (in case the template was corrupted for some reason)
  • Made three test prints
    • Original file with RR Pecos River Gloss V-1 profile
      • Still way out whack
    • Original file printed with the standard sRGB profile
      • The closest to replicating my original master print, but still not a satisfactory matching of my screen and output like I had achieved prior to whatever seems to have gone sideways.
    • Brand new file, with the RR V-1 profile
      • No difference, the RR profile is still way off for some reason.
benprintshop
Okay, so far this seems to have worked:
1) I manually select paper settings on the printer
2) Installed the Canon Professional Print & Layout, THEN manually install the PPL plugin, into the Ps application plugin folder.
In shop, open the file you want to print, then go to File -> automate -> you'll see the PPL plugin.
I still don't know why I was able to directly print from Ps, and then suddenly wasn't able to, but I'll have to spend time figuring that out later.
3 REPLIES 3
jrhoffman75
I have a Pro-100, but your printer might be the same. Access the Printer Utility via System Settings-Printers & Scanners.
You didn't mention this, but did you try reinstalling the printer driver?
benprintshop
Thanks John!  I was able to figure out how to print directly from the Canon PPL plugin through shop.
Appreciate you taking the time to help me troubleshoot this!
Holiday
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R5C - Version 1.1.1.1
EOS C80 - Version 1.0.3.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
