07-17-2015 06:30 PM
I've tried all possible avenues, even Canon do not have the answer. In Lightroom5, after selecting, developing and entering the print module, I open the Print Studio Pro (PSP) plugin. If I want to print a 13 x 19 image, everything is fine. If I want to print more than 1 image - 2 8" x12", I can only get 1 image to print. I've selected the "borderless x 2" option in the registered layouts panel, but still only 1 image appears on screen and will only print 1 image. I was told that PS 2015 (I have PS CC 2015) can work with the PSP plugin, but this is not the case. My workflow is now suffering as you can imagine the ways I'm trying to work around this. Canon tell me that Adobe update more regularly and I just have to wait for a fix from the Canon engingeers. Does anyone have any suggestions?
07-17-2015 08:03 PM - edited 07-17-2015 08:12 PM
You have to control-click the two images in the Library Module. Then when you go to the Print Module LR will show two images to be printed.
Open PSP and the two images will show in the bottom filmstrip.
07-18-2015 07:21 AM
Wow, that was easy. Thank you so much. Do you have any experience of using Hahnemuhle papers? I've downloaded the ICC profile to the pro 1, yet in PSP plugin, the paper size is wrong, I can't get it to print 13 x 19. Any suggestions?
07-18-2015 07:40 AM
07-18-2015 08:55 AM
I"m tryinjg to use Hahnemuhle Matte Fine Art German Etching, 310 gsm
07-18-2015 09:53 AM - edited 07-18-2015 09:54 AM
I don't use that paper, but do use Museum Etching.
Try setting up PSP as shown below; it works for me.
Select the appropriate ICC profile for your paper![]()
07-19-2015 03:20 PM
If you have LR5 and know how to use it you don't need the extra step PSP. LR5 will do everythimg you want by itself.
