03-28-2015 10:45 AM
Is there a language setting I missed?
03-31-2015 10:20 AM
Who knows.Can't readit!
03-31-2015 10:24 AM
Thanks for straightening that out. I kinda had the same problem.
03-31-2015 10:29 AM
03-31-2015 10:53 AM
03-31-2015 03:54 PM
Why are you using it, or trying to use it? LR and/or PS do not need it.
03-31-2015 04:48 PM
Using it because: (1) I'm new at this printing business; (b) it is a plugin and as such provides the same interface look and feel in LR and CS6; (III) it seemed to be recommended by the guys at the camera/printer store; and (D) I'm new at this.
03-31-2015 05:11 PM
"... the same interface look and feel in LR and CS6"
Anybody that masters PS and/or LR does not need PSP. It does nothing that those two great programs don't.
Drop PSP and learn how to use PS. PS is better than LR for printing.
"(D) I'm new at this."
So was I at one time as was everybody.. You will learn.
03-31-2015 05:12 PM - edited 03-31-2015 05:13 PM
Read this over and follow it closely..................
First, you must not let the printer set anything. Turn off every bit off control it has. You can do this with the Canon My Printer under the Printer Settings tab. Do you know how? I will guess, yes, for now but if you don't get back to me.
Second, you need to have your photo editor (like Photoshop) handle all the settings and color matching. You know how to do this? I prefer Photoshop and I use AdobeRGB color space.
And lastly, it is essential you get some settings on your monitor that somewhat matches what the printer is printing. Your printer may be doing exactly what you are telling it to do and you have no idea it is, because your monitor is so far off. If you don't do this step, you can forget the other steps. However, there are only a few things that you need to be concerned with. You don't need any fancy extra add-ins to do this. No additional software or gadgets, no spiders or monkeys, etc.
Most people set their monitors too bright.
You must get the gray-scale very close. You need to get the brightness very close and you need the contrast very close.
After you do these things you can make adjustments to your prints by just looking at your screen. Because you know the monitor and printer are on the same level. One more point, you can NOT get a printer to print every color exactly the way you saw it. It isn't possible as all colors and adjustments effect all others. My goal is to get the skin tones right. That is what people notice most. Remember you are dealing with two different disciplines here. One is colored light and the other is colored dyes. They are not the same thing.
For instance, I know my Pro-100 tends to print darker than what I see on the monitor (typical). So, I automatically know to set it's prints 1/2 to one stop brighter in Photoshop, in my case. It also prints with a slightly warn tone. Most of the time, with portraits especially, this if OK but sometimes it is not. In that case I adjust the "temp" setting slightly cooler in PS.
All the Canon photo printers I have ever seen have this warm/magenta cast. Canon engineers must prefer this look. It can not be changed. You need to "fix" it in post.
Make sure you have the correct ICC profiles and you are using Canon brand ink and paper until you get good with the printer. Very, very important, otherwise you don't know if the printer is doing exactly what you are telling it to or not.
Important is, use the USB connection until everything is right. You are just adding another issue when you try to set up the printing and the wireless all at the same time. Just like using Canon branded products until it is a go. Use a real printer USB cable. Not just any old USB cable. Get everything right before you explore.
If you need help on how to turn off the printer controls or how to set up PS let me know.
04-05-2015 12:34 PM
EB – thanks for the detailed explanation. I had to shelve the printer project for a while, but am back on it today. I have looked at the printer settings with My Printer but the only setting I see that might need to be changed is Color/Intensity in the Main tab which is set to Auto.
In Photoshop the salient settings are:
In Lightroom (which is my preferred application), the print settings look the same as displayed in My Printer. I can’t find any other place to set printing options.
As for my monitors (I have two):
So – I took a shot of a Tulip, it has yellow, greens and black in the image. Adjusted it to my satisfaction in Lightroom and printed it from LR. The image looks pretty good but the yellow petals of the flower are too orange. Much better, at least for this image. I then opened the same image in CS6 and printed it again. The images are nearly identical. I think the PS image is slightly (very slightly) better in that the petals are not as orange. I am running out of gray ink so I can’t do much more testing until I get another.
Thanks for your help and please critique the setups I have done.
