07-04-2023 04:38 PM
I am unable to print borderless pictures above 8.5x11 in size. I have tried all the various options out there in terms of what to check, uncheck, etc. I am using a MAC with Ventura software. Suggestions would be greatly appreciated.
07-07-2023 10:44 AM
When you installed and added the printer to your Mac, did you select the IJ Series version of the printer or the Airprint version?
Also, if you would like to resolve this issue in real time, I recommend reaching out to Canon support.
You will need to register your Canon gear HERE to access additional support options.
07-07-2023 11:56 AM
@DEHenry wrote:I am unable to print borderless pictures above 8.5x11 in size. I have tried all the various options out there in terms of what to check, uncheck, etc. I am using a MAC with Ventura software. Suggestions would be greatly appreciated.
ArthurJ has the answer. Go back to System Settings, Printers & Scanners, click the “+” button to add a printer and wait (could be several minutes) for the real Canon driver to appear.
I am assuming you downloaded and installed the Canon driver from the support website. If not, you need to do that.
