Pro-300 printer won't print
will1969
I have been using the Imageprograf Pro-300 for over a year with Lightroom and have had no problems.  Now any time I try to print it just says Error printing - no code or further explanation.  I have been fiddling with this for a week with no luck.
paulcmiller
Hi will1969,
I finally resolved the issue after an hour of Canon support. Took forever to find the problem....The solution was to "disable the IP settings for IPv6" and to leave IPv4 alone. Here's how...
Home--LAN Settings--WiFi--Settings---Advanced--TCP-IP Settings---IPv4, IPv6....Click on IPv6 and "disable" it. This worked for me. I hope it helps you.
3 REPLIES 3
Patrick
Hi will1969,
Does an error appear on the display of your imagePROGRAF PRO-300 ?
What version of Windows are you using?
If you are using a Mac, what version of OSX is installed?
Are you using your imagePROGRAF PRO-300 wirelessly?
Or are you using it with a USB cable?
jrhoffman75
Does it print a nozzle check and/or from other software?
paulcmiller
Hi will1969,
