12-29-2020 07:55 PM
Tried my first print on the sample of Premium Matte A, letter sized, defauilted 25mm borders.
Black ink bled all over from the dark areas.
I printed from PShop, using PShop with ICC set to Canon Premium Matte A. Selected same settings on the P-200 setup pages also.
Made a mess.
What is wrong?
Thanks
12-29-2020 08:49 PM - edited 12-29-2020 08:49 PM
@DrNo wrote:Tried my first print on the sample of Premium Matte A, letter sized, defauilted 25mm borders.
Made a mess.
What is wrong?
Thanks
Welcome to the forum.
Sometimes this happens when the paper is inserted wrong side out.
Wet a finger tip and touch a corner of the paper. The side you want to print on will feel sticky/tacky to the touch.
12-29-2020 09:50 PM
Thanks for the quick reply.
You solved the problem when you said one side is sticky (I know that trick from printing in the color darkroom).
I wondered why you said that, because sheet I used was thick and back side looks like cardboard.
I printed on the white side of the cardboard sheet that is in the front of the package!
First time user of both that paper and the printer.
I had made a semi-gloss print aftewards and that came out perfectly.
So far, that printer is doing a remarkable job matching my proofing in PShop.
BTW. the cardboard print isn't bad, just lower resoution and the black lines are fuzzy.
Thanks,
Dr. No
