Pro 1000 small band
maucamo
Enthusiast
Nozzle perfect, head aligned, tried unidirectional and non unidirectional, tried avoid abrasion off and on, custom icc, tiff 16 bit, Lightroom.
This is not a banding, I think. That's happen from 3 cm. to 6 cm from the upper right part (at the end of the print), then lines disappears and all print is perfect. That happen only on glossy paper (with gsm 300). Printer is connected via lan. Printer driver ok.
What can I try?
2 REPLIES 2
Patrick
Hi maucamo,
What version of Windows is installed on your computer?
If you are using a Mac, what version of OSX is installed?
Are you using your PRO-1000 wirelessly?   Or with a USB cable?
Who is the manufacturer of the paper that you are using and what specific type is it?
Mac osx 10.15.7 connected via lan (tried also usb) paper is Canon pro platinium and Ilford Galleri smooth pearl. They are resin coated about 310 gsm lustre A3 format
