09-29-2020 12:03 PM
Hello,
I am using a Pro 10 on a Mac with Capture One. I am trying to make a B&W print on Moab Entrada Bright 190 paper, printing for a frame with a mat opening of about 9.5" x 8".
I have read through this forum on how to get past the art borders however I am having a problem accomplishing this and still get a good print. I am able to get a print with my required dimensions by:
Matte photo paper I thought would be closest to the Entrada which is a rag paper.
My print is close to the dimensions I need but the problem is the quality of the print is poor, very washed out. I am assuming this is because the media type is wrong.
I was able to get a print with the correct dimensions using Canon Pro Luster (isn't that art paper too?).
Can someone suggest better settings so that I can print with the dimensions I need and use the correct media type? I have tried various combinations including Letter Borderless, using the ICC profile for Entrada and some other combinations.
Thanks.
09-29-2020 03:10 PM
Since Moab could have selected Photo Paper Pro Premium Matte and didn't I would agree that selecting Matte Photo Paper would not be the best choice.
I don't have a Pro-10, so I can't personally verify, but it is my understanding that the Pro-10 doesn't utilize all the black inks unless the fine art paper selctions are being used. If you print a color image using the same paper and settings do you get a good image?
All you can do is try the various non-fine art paper choices and see what does the best job. Luster is not a fine art paper; in the Canon world fine art papers are heavy weight papers that need to be fed through the manual feed tray.
Do you have larger paper that you could trim down?
Maybe Rick (shadowsport) will see this and provide more guidance.
09-30-2020 07:32 AM
Thanks John, I thought of printing on larger paper but it felt like a hack rather than a solution. I guess that's the way to do it.
Michael
