10-13-2022 09:40 AM
When I try to print to the multipurpose tray on the PRO-200, it cuts out the area in the center (where the center of a CD/DVD would be) - is there any way to disable this?
10-14-2022 11:51 AM
So we can best assist you, please reply with the answers to the following:
If you would like assistance in real time, I recommend reaching out to Canon support for this issue. You will need to register your Canon gear HERE to access additional support options.
10-14-2022 01:55 PM
1. macOS 12.6
2. Canon's Nail Stickers. I do not want to use a Canon application to design or print though.
3. Let's say a PDF being printed via Preview.
10-21-2022 12:35 PM
I understand you dont want to use a Canon program but just as a test does the same thing happen when using Canon's Easy-PhotoPrint?
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.02/07/2023: New product announcements!
