04-18-2019 04:53 PM
I'm looking for Canon paper ICC profiles to download and can't find them.
Pam
04-20-2019 11:00 PM
Finally uninstalled software and re-installed and all is GOOD!!!
Thanks for you help
04-18-2019 08:41 PM - edited 04-18-2019 08:56 PM
Try these 3 links . There’s a section on ICC profiles
https://ugp01.c-ij.com/ij/webmanual/PrintStudioPro/W/1.3/EN/DPPG/dppg_2-05.html
https://ugp01.c-ij.com/ij/webmanual/PrintStudioPro/W/1.2/EN/DPPG/dppg_2-07.html
04-18-2019 11:03 PM
04-19-2019 03:00 PM
Where can I locate them on my MAC? I don't see them when using Lightroom Classic CC to print.
04-19-2019 03:04 PM
In Lightroom when you select the ICC profile dropdown if you don't see the profiles you want select "Other" and then select the ones you want. LR doesn't pre-populate.
04-19-2019 03:29 PM
That's my problem my Profile choice is "Managed by Printer" it doesn't show Canon Pro 100 and other doesn't show Canon Icc profiles either. That's why I'm thinking the ICC profiles aren't on my MAC.
04-19-2019 04:05 PM - edited 04-19-2019 04:06 PM
1. Uncheck Display profiles.
2. Have you selected the Pro-100 printer in the Printer radio button?
This is from a Windows machine, but macOS is similar.
When you added the printer to the Mac is it the IJ-series printer or the AirPrint printer? You don't want AirPrint.
I will log onto my MacBook next.
04-19-2019 04:11 PM
04-19-2019 04:41 PM
Yes I do show my printer as yours does on the MAC on both screen shots. I just don't know where the Canon Paper profiles would show up? They do not show under other when I uncheck display profiles.
04-19-2019 04:52 PM
try downloading and reinstall the Canon printer driver from the website:
That frequently straightens things out.
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
