02-05-2022 03:20 PM
Is my PIXMA Pro9000 Mark II compatible with Windows 11 - i can't seem to have the laptop find the printer. HELLLLLP!!!!!
06-22-2023 01:32 PM
Thanks for this. Although it seemed to work for someone else who replied a few months before me, it didn't work for me. The Canon Pro9000II printer appeared in the Software devices, but the only driver available was a generic one. That did not seem to be enough to make the printer appear under the Printers section. Has anyone else had any luck getting this printer to work with Windows 11?
07-07-2023 08:20 AM
You are AWESOME!!!!! I had to buy a new laptop and it has Windows 11. I spent 6 hours re-downloading the driver but at the end of setup connecting my printer it stated it couldn't find my printer. I happened upon this post after 6 very long frustrating hours and it worked perfectly! You are a lifesaver! I love my Canon Pro 9000 Mark 2 and hate to give it up. TY TY TY TY THANK YOU!!!
09-30-2023 06:01 PM
I'm getting the same result - did you ever find a solution?
05-27-2024 09:39 AM
In Device Manager my Canon Pixma Pro9000 Mark II isn't listed for me to select it and look for updated drivers. My PC is not recognizing the Pro9000. How do I get around this and do what others have done successfully?
07-12-2025 12:31 PM
I finally got this old beast to print in Windows 11. I couldn't even begin to explain the convoluted steps that actually made it work, there were a few botched attempts in there where I messed with manually assigning port but I think that was all irrelevant.
My best guess on the actual way to do this: I had to uninstall it from device manager while the Windows 10 driver provided from Canon was running on the "connect to pc, turn on printer, this can take a while" step. So while it's on that screen, you uninstall the driver under Universal Serial Bus controllers, then "Scan for Hardware Changes". This caused the Canon driver to complete successfully. Then I installed the XPS driver, also provided from Canon. Then, when I wanted to print something in my web browser, I had to use the system dialogue (under More Options). Just printed a page with 4+ year old ink and it surprisingly looks great!
07-12-2025 01:43 PM - edited 07-12-2025 02:12 PM
Canon makes great printers. 🙂
Yours is 16 yrs old. For compatibility and reliability, it might be time to consider investing in newer printing technology. 😉
12-03-2025 11:51 AM
I just installed the Pro9000 Mark II on a Windows 11 computer. I wasn't able to get it to work using the Device Manager instructions shared by thekoos, so I wanted to share. Here's what I did:
I also restarted my computer several times during the process. I'm not sure if it helped, but figured I'd mention that. Good luck!
