01-24-2023 09:16 PM - last edited on 01-25-2023 08:19 AM by Danny
I cannot find a way to custom print. I would like to use 12 x 16 and 18 x 24 frames. Help!
Why send me 13 x 19" paper with my Pixma Pr-200 printer purchase when I am going to waste so much of it ? Why make it sound like I have choices, when it only will print a set of predefined formats? I could not find a answer in the manual that would work with my Mac.
01-25-2023 07:34 AM
1. The Pro-200 is a 13” printer, so it is never going to print an 18x24 print.
2. You can print a 12x16 image on 13x19 paper and trim.
01-25-2023 02:14 PM
You misunderstand. I would like to print close to a 10 x 14" or a 12 x 18" print, a different aspect than Canon's set sizes, so I can use my existing mats and frames. Is this impossible?
01-30-2023 01:11 AM
Why doesn't my pro200 printer print panoramas?
01-30-2023 06:29 AM
@gas_canon200 wrote:Hi,
Define your idea of a panorama. You can print up to 13"x39", which is a 3:1 panorama.
01-30-2023 08:20 PM
I am using 13x38" paper.
There are several problems
1. It will only part of the image. Approximately 6 inches and then spits out the paper.
2. It prints parallel black lines approx. one inch from image top and bottom.
3. In the print dialogue box it show the print in alignment with the outline of the paper but prints the opposite. I've wasted paper and ink trying to get to work. It seems to me this should be a straight forward process.
Are you employ by Canon?
Thanks
01-25-2023 04:02 PM
12x18 is a perfect size image for printing on 13x19 paper - 1/2 inch margin all around.
The printer driver will allow custom sizes; it's explained in the manual for the printer.
12-12-2024 02:11 PM
You have not answered the question. We all know how to set custom sizes. What was asked was "Why does the printer not print the size that we have indicated, when it is not one of the standard sizes?" I have had this problem as well. I select 13x39, set margins, the print page shows that it will print appropriately and then the printer sizes it down significantly and prints the black lines (I assume the cleanout lines for the jets) on the paper. Is there a fix for this or is the pixma-200 just a bad printer?
