02-23-2019 08:40 PM
I recently got my pixma pro 100, i set it up completely then did a test print of a photo i was working on with 8.5 x 11 pro luster paper...the print came out fine so i let the printer sit for a few weeks and when i got time i edited the photo the way i wanted and then printed it on a 13x19 pro luster paper that i planed to frame, i did two prints on that size paper and one on 8.5x11...ALL THREE came out a bit dull, the bottom of the photo has a section completely smudged/smeared (the photo ends and then there's this smudge/smear before my border) then on the right side of each photo there's is a multicolor border after the photo ends before the actual border(PICs ATTACHED, SOMEONE HELPPPP)
03-01-2019 08:44 PM
I found the reason for issues with my prints, i saw another thread here that pin pointed the answer, Flattenening my image/merging layers before i print.
02-25-2019 09:53 AM
I'm not sure what I'm looking at. Did you spec a black border for the print?
Did you run a nozzle check to be sure everything is firing correctly?
Can you point out more clearly what the problem is?
What software an OS are you working with?
03-01-2019 08:44 PM
03-01-2019 08:55 PM
BEFORE & AFTER ATTACHED.AFTER image i was at a frame shop picking out a mat (went with thebottom right btw)
