12-31-2014 06:54 PM
Any suggestions?
I noticed my prints looked bad and I noticed that I hadn't filled the yellow in a while. I ran test pages and that was the only color not printing.
I figured the ink was old and I put in a brand new yellow ink and it still doesn't print. I tried deep cleaning and the printer doesn't think anything is wrong. Also if I touch the tip of the yellow ink on a napkin, yellow ink does come out.
thanks
01-01-2015 09:42 AM
Try this: http://www.castleink.com/category/82/Cleaning-Clogged-Canon-Print-Heads.html?language=en
01-02-2015 10:01 AM
Did you not use your printer for a long while. Like a month or so? If you have been using it regularly, say even once a week, it isn't a clogged print heard. Most likely, I mean as anything is possibile. The best practice is to print something at least once a week or two.
When you manually try to clean the print head be careful as there are gold contacts and electronic contacts there.
01-01-2015 09:42 AM
01-01-2015 10:58 AM
thank you, I will try that
01-02-2015 10:01 AM
01-02-2015 10:16 AM
Thanks to both of you, it's now working
