06-02-2017 10:18 AM
Most of the time, I am using 2 networked PCs, each with their own printer set as the default for that PC. I use the PRO-100 only on occasion for printing 13X19 photos. However, when I turn it on, it takes over as the default printer on both PCs. When I'm done printing, I have to reset the default befor I use any other applications.
I would like my default printers to stay as they are, any direct the print output to the PRO-100 only when needed. Any suggestions?
Thanks,
McSynth
06-02-2017 12:59 PM
To have a better understanding of your issue, please let everyone know what operating system (Windows Vista/7/8 or Mac OS 10.X) you are using. That way, the community will be able to assist you with suggestions appropriate for your product.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/CanonEmail or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks!
06-02-2017 03:56 PM
Thanks John_B,
Both my PCs are using Windows 10, and one uses a Canon MG6220 by default, and the other uses an HP PhotoSmart D110. Those 2 and my Pro-100 are connected by WI-FI through Netgear N600 Dual Band WI-FI router.
As soon as the Pro-100 is powered up, both PCs change their printer default to the Pro-100, and it remains that way after the printer has been powered down.
