08-16-2021 08:26 PM
On a Pixma Pro-10, can you print on a sheet longer than 19" and if so, how?
thanks!
08-17-2021 08:25 PM
08-17-2021 07:52 AM
@mossprojects wrote:On a Pixma Pro-10, can you print on a sheet longer than 19" and if so, how?
thanks!
Welcome to the forum.
Go into your printer driver, select Page Setup, select Custom Paper Size in the dropdown. It will give you the maximum length (height) you can print.
08-17-2021 08:25 PM
that works nicely, thank you!
