07-23-2024 01:12 PM
Hello,
I need some help to figure out what is wring with my printing workflow.
I've been having major issues with a magenta cast recently, I'm honestly at my wit's end.
As the subject of the message details, I'm trying to print Jpeg images on my Canon Pro-10s using both Lightroom Classic and the Canon Print Studio Pro Plug-in software.
I of course know of the dreaded double profiling issue from having found multiple discussions on here, but am truly unsure as to how to fix this after having tried every single possible combination of fixes.
this is what my settings look like when printing from LrC directly
this is what my settings look like when printing from LrC directly.
I keep 'Profile: Managed by printer' and select ColorSync.
have of course tried different profiles. I have also tried to select an ICC profile from LrC with Canon Color Matching at no avail.
have of course tried different profiles without leaving it in Automatic.
have also tried to select Adobe RGB as I have come across a Forum discussing a possibility of magenta cast when using sRGB as opposed to Adobe RBG. again, at no avail.
this is what my settings look like when printing with Print Studio Pro PlugIn
his is what my settings look like when printing with Print Studio Pro PlugIn.
the output print looks mostly the same with every single thing I have tried: there is a really strong magenta cast and it looks like double profiling.
Please help!
07-30-2024 10:53 AM
just printed it. Looks fine to me, although there is a slight magenta shade on the right side of the PM cartridge mark. Could just be head mis-alignment. Everything else seems normal.
would this mean the issue likely lies with software?
thanks for the help,
Val
07-30-2024 11:04 AM
Check your M and PM cartridges. According to Canon M should be darker than PM.
07-30-2024 11:40 AM
It is a bit lighter bust still doesn’t look as light as it should be. I would say it’s the same intensity as the Magenta ?
07-30-2024 11:43 AM
Sorry, I forgot to add that I have changed the PM cartridge with a new one.
07-30-2024 11:44 AM
Are you using Canon inks? My Pro-100 shows a similar pattern of PM lighter than M. The purpose of the “P” inks is to give a greater range of color.
07-30-2024 11:50 AM
No, not using canon inks as they are too expensive. It’s a German manufacturer and I’ve printed before with them without this issue. Do you think it could be an ink problem? Is there a way I can do an overall clean and start from scratch?
thank you, Val
07-30-2024 11:54 AM
Was there an ink cartridge change between when you were getting good prints and problem prints? Maybe contact the ink supplier. Perhaps a quality problem.
07-30-2024 12:23 PM
Will do, I’ve done more tests and it persists. Is there any way I can do a full nozzle clean and start fresh? Do you have any recommendations for decent inks that won’t break the bank ?
thanks for the help
07-30-2024 12:41 PM
I don’t have any direct experience, I use Canon ink, but many folks report good experience with Precision Color inks.
A friend installed P and PC backwards in his Pro-100 and two cleaning cycles straightened him out.
07-30-2024 12:51 PM
I’ve done four more full cleans in the meantime and it seems to be getting better.
There are still a few images where a can see a slight cast but I will run more cleaning cycles
If this slight cast still persists I will try the cyan swap you suggested, but the worst is definitely fixed.
I was sure it was double profiling but it looks like that was it!
Thanks so much for the help John, truly a Legend!
Val
