07-31-2021 03:11 PM
I would like to know the location of my printer (Pixma Pro-200) ICC profiles for Canon paper.
For other (non-canon) papers, I know how to download and use ICC proviles when printing from Photoshop. Howver, if I want to have Photoshop manage colors when printing, I have to specify a Canon paper ICC profile. But I can't find the files.
Somewhere I read that they are included in the printer driver, but that info doesn't help if I can't find the files.
Help would be appreciated. Thanks.
08-02-2021 09:55 PM
Are you saying that when you use the profile drop down selection box in Ps the Canon profiles don't show up?
Are you on a PC or Mac?
If on a Mac do you have the Canon IJ Series version of the printer (and not AirPrint)?
08-02-2021 10:01 PM
Correct. The Canon profiles are not listed in the profile dropdown selection box in Ps.
I'm on a Mac...
...and am not sure what you mean by the 'Canon IJ Series' verson of the printer. I am not AirPrinting. I am using a wireless connection to the printer, and have the Driver Version 22.20.0.0 installed.
Thanks,
BPBear
08-02-2021 10:18 PM
I don't have a Pro-200 (I have a Pro-100). I didn't' need to do anything special; the profiles just show up in the drop down.
Do you have any profiles in the drop down?
Do you see the profiles if you try using Preview?
Sometimes reinstalling the printer driver will reset things.
If that doesn't work you probably need to contact Canon support at 1-800-OK-CANON.
08-02-2021 11:19 PM
I have several other sets of profiles in the drop-down, every one of which was downloaded from the web sit of the manufacturer of the paper. But Canon has NO information about how to download profiles for their papers. One or two sources I've located seem to indicate the Canon profiles are included with the driver. However, I can't find anything like 'profiles' associated with my profile download(s).
And, yes, I've tried repeating the download and (re)install of the driver. Nothing.
Also, I'm not sure what you mean by using 'Preview.' Whenever I start the 'Print' process, the window that opens displays a preview.
I guess I'll turn to Canon Support, although the hold times are really looooong.
BPBear
P.S. The print head on my Pro-100 died and the only option was to move to the Pro-200.
08-03-2021 06:21 AM
What Imeant was the Preview application. Just to see if it is something related to Photoshop.
If it is the subscription Photoshop you could also install Lightroom and see if the profiles are in Lr.
In Lr if you don't see the profiles select Other and then all the profiles are revealed. Check box the ones you want to show up next time.
It's been a while, so I don't recall if the same process was needed in Ps.
08-03-2021 11:16 AM
Thanks for the tip about using Preview to check for profiles.
When I did use this App, I found all the other profiles I've installed, but there are no profiles for Canon paper.
Similarly, when using Print in LrC, I see those other profiles but nothing for Canon paper.
For other papers (for example I print a lot of note cards on different types of paper), this is the process I use, i.e., look in the list of profiles that is revealed when I specify that Ps manages color. But whether in LrC or Ps, there are no Canon paper profiles listed.
When I downloaded profiles for the other papers, I had manually to copy/move them to the place where Mac OS keeps such information. When I look in that folder after installing - or reinstalling - the printerr driver - there are no Canon profiles. That's why I posed the question about where Canon might have put them.
Thanks for your suggestions.
08-03-2021 12:46 PM
08-03-2021 02:20 PM
Here's what I see in Printers & Scanners:
This displays the printer I expected to see and that I use for photo-printing.
...But then I went back to the beginning - downloaded the driver softward again and re-installed to be sure I wasn't defaulting to something, e.g., AirPrint, along the way. It turns out the installation offers no choices at all. Then I deleted the printer shown in the pic above, and then 'added' it back again. This time I could see where someone might choose the 'first option', i.e., AirPrint. I had never done that, but this time I went one step further. I not only selected the Canon Pro-200 Series (as shown below), I also decided to 'Select Software.' From the dropdown (shown below), I chose Canon Pro-200 series from that dropdown..
After completing the new printer setup and turning to Ps - there were all the Canon paper profiles. I'm not sure which part of this last sequence actually produced the profiles, but I now have them and can stop relying on printer color management.
Thanks for persistent nudging...
08-03-2021 03:38 PM
