08-14-2015 07:05 AM
As per the title how do I print in B&W/grayscale on the Canon Pixma Pro 100s using a Mac? When using PC you get the option to check the box saying black and white in the printer driver settings, but on Mac there isn't one. If you go to colour matching you get the option for colour sync where you get the option of Auto or choosing a colour profile, or canon color matching. If you go to colour options you can fine tune CMY etc, but still no B&W option
Can anyone help please?
08-14-2015 09:17 AM
I don't use a Mac but why are you not just doing this in the post editor like LR or PS or some other editor? That is where it is normally done?
08-14-2015 09:25 AM - edited 08-14-2015 09:25 AM
Perhaps this will help:
http://www.cnet.com/how-to/the-buried-mac-setting-that-can-save-your-inkjets-color-ink/
08-14-2015 09:27 AM - edited 08-14-2015 09:29 AM
Thanks for the link, that works 🙂
@ebiggs I'm just interested to see if it saves the colour ink and printing from LR still uses the colours even though the image is B&W
08-14-2015 09:57 AM
I have read online (FWTW) that the Grayscale option should only be used when you want to convert color images.
If you have a B&W file it should be printed "normally" since the inks are not pure black The printer driver adds small amounts of color to compensate for the ink and paper properties.
You will be able to verify/disprove this with your own testing.
08-14-2015 10:28 AM
Thanks. Yes this was my concern was was going to run small proofs before printing large.
08-14-2015 12:58 PM
I concer. It will not save your color inks. The printer and all I know of are not capable of printing 256 scales of gray with one, two or even three black cartridges, It does make sense?
The Pro-100 can not print true B&W at all. Another factor is the paper you select. Red River has special B&W paper for this printer. Check them out.
08-14-2015 01:19 PM
Thanks, I'll look into that paper. I'm just using Canon Pro Platinum at the mo. I've heard that there are some papers that almost give a metallic look and look good with B&W, any idea what this might be?
08-14-2015 02:14 PM
Contact Red River. I use Polar Pearl Metaclic.
