Grayscale printing, when to use?
Tinman
Enthusiast
I have a Pixma Pro-100. Under what circumstances would I print in “grayscale”?
Nikon D600; Nikkor 50mm f/1.8G, 85mm f/1.8G, 70-300mmG f/4.5 - 5.6 VR
Hello Tinman.
When the "Black and White Photo Print" is checked and the printout begins, the document is converted to grayscale data. This option allows you to print color items in monochrome.  The black and gray tanks would primarily be used when this option is selected.
6 REPLIES 6
ebiggs1
To set-up your monitor!Smiley Happy
EOS 1DX and many lenses.
“To set-up your monitor!”
What does that mean? If there are three monochrome inks, is there a need to print in “grayscale”.
A gray scale can be helpful in matching your monitor to your printer. If your monitor does not show you what your printer is going to print, you are wasting time and materials.
You can hold up the sheet of gray scale print out right up next to the monitor and make a good comparison. Some people do this better than trying to match colors.
I understand what you are saying but I think that I am asking a somewhat different question.
I thought that “Grayscale” printing involved blending the color ink to arrive at different shades of grays. The Pro-100 has three monochrome inks, which should print in various shades of gray. Under these conditions, when (if ever) should grayscale printing be used? When I check the ”Print Black & White photo” box is that the same as printing in “grayscale”?
Hello Tinman.
Michael:
Thanks for the answer.
