12-20-2013 12:47 PM
I just installed a new Pixma Pro-100 and did the printhead alignment without issues. Printed my first test 8x10 print and while I printed beautifully, there are faint (barely visible) white lines on the print. Any ideas on how to fix this? Another printhead alignment maybe??
Thanks for you suggestions!
07-07-2017 10:41 AM
I was able to fix the issue. It was in my settings. When you print something click on "print settings" then in the pull-down menu go to Quality & Media, and make sure it is set to "finest". Somehow it was set on "fast" which was causing the lines. Once I switched it "finest" it corrected the problem. I hope this helps and good luck!
12-21-2013 08:37 AM
There is no way to get white on a print except to not put any ink on the page. So, yes, I would run the alignment utility again as a first step.
Now this assumes you are using Canon brand ink and paper. Always, always use Canon products to set-up and learn any Canon printer. ![]()
12-22-2013 11:13 AM
I would recommend a cleaning first and then check alignment.
07-06-2017 04:34 PM
I'm having the same problem and have cleaned muliply times and aliended the head with no luck. I use canon ink and paper. Can you help me solve this problem. Very frustrated. Susan
07-07-2017 07:35 AM
What paper and settings are you using?
can you post a photo of what you are getting?
07-07-2017 10:13 AM
"... have cleaned muliply times and aliended the head with no luck"
Susan,
Once or twice is enough. If that didn't correct it, it won't so multiple times is useless and wasteful. Yes, a sample would be nice to see.
First thing to check is the paper profile you selected. Does it match the paper? You would be surprised how many folks forget this or get the wrong one.
07-07-2017 10:20 AM
Susan,
Here are soem tips I use.
First, you must not let the printer set anything. Turn off every bit off control it has. You can do this with the Canon My Printer under the Printer Settings tab.
Second, you need to have your photo editor (like Photoshop) handle all the settings and color matching. I prefer Photoshop or Lightroom.
Make sure you have the correct ICC profiles and you are using Canon brand ink and paper until you get good with the printer. Very, very important, otherwise you don't know if the printer is doing exactly what you are telling it to or not. This is a must!
Important to, use the USB connection until everything is right. You are just adding another issue when you try to set up the printing and the wireless all at the same time. Just like using Canon branded products until it is a go. Use a real printer USB cable. Not just any old USB cable.
07-07-2017 10:41 AM
07-07-2017 04:49 PM
"... it was set on "fast" which was causing the lines."
That'll do it. Good find.
03-14-2021 01:23 PM
Thank you so much for posting your fix. I stupidly had mine on "fast printing" as well. I was going crazy thinking something was wrong with my new printer!
