Reply
New Contributor
Re: Color Managament in ProGraf Pro1000
Just a quick note. New PRO-1000 and I too kept running into "no printer found" messages in Canon's Print Plug-in Studio.
The fix presented by John and Paul worked.
A few extras in case others run into the same problem.  I created two printer names
  • one using Apple's Bonjour process
  • a second specifying a the device IP address
Once the printer's configured to use a device IP address the Print Plug-in successfully connects,. Also, Lightroom no recognises the printer's loaded Canon ICC profiles when you Soft Proff the image and select a profile. IMO, the BIGGEST benefit.
Good luck, I hope the info helps
New Contributor
What menu options do you now have? I don't see how to turn off color management using PRO-1000 on a Mac?
VIP
Select Color Matching. It should be grayed out. If not select ColorSync.
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
New Contributor
Thanks, John. I keep reading and found where you helped someone else with this, as well. :-)
powered by Lithium
