12-04-2014 02:45 PM
12-04-2014 03:28 PM
12-06-2014 07:11 AM
If I understand correctly, when you print from Silhouette Studio on plain paper using the plain paper setting it looks OK and you are pleased with output. But, when you print on the specialty paper it doesn't look good? Am I correct?
If so, does the specialty paper provider suggest a paper profile, or provide one?
If not, you will need to try different profiles that come with the printer and see which one works best. If you get close you can adjust individual color effects in the rpinter driver and save the settings.
