Canon ipf 655 e161-4050 error
tommen
I replaced the printhead of the ipf655 plotter and now im getting this error. There is bearly any ink in the ink lines of the plotter. I just replaced all the ink cartridges, so what now? Im a bit lost. Im currently in admin mode on the printer trying to "clean the printhead"
1 REPLY 1
Based on my research, I believe this error indicates a purge motor failure.  Cause, an over-heated print head or using non canon inks.  Basically the printer will not prime itself.  I suggest you engage with Canon Support.
If you are outside the US, you can do this here:
For Product and Support Information | Canon Global
